GMC K1500 front hub removal
DPAYNE
I have to replace the wheel studs on my left front hub/brake assembly, which requires removal. i followed all the steps from my Haynes, removed the hub locking mechanism, but the thing still won't come off. am i missing something? any tricks to motivate this thing off of here?
1986 GMC K1500
mileage: ??? high ???
engine: custom 350[img:b97257ed09]http://www.2carpros.com/forum/automotive_pictures/60761_hub2_1.jpg[/img:b97257ed09]
[img:b97257ed09]http://www.2carpros.com/forum/automotive_pictures/60761_hub1_1.jpg[/img:b97257ed09]
Feb 23, 2007 at 2:50 AM
CHEVY22
  • 1,375 POSTS
will the ring in the pic come off , because if i remember right it should spin off allowing access to the outer bearing and essentially allowing the rotor to come off
Feb 23, 2007 at 3:21 AM
DPAYNE
looks like it should spin off, but i couldn't get it to budge loose (used a pair of pliers wedged in there) is there a special socket for this?
Feb 23, 2007 at 3:41 AM
CHEVY22
  • 1,375 POSTS
there is a special socket for the nut , you should be able to pick it up at any large auto parts store or sears
DPAYNE
i'll do that. thanks a bunch. donation on the way..
this site is great.
Feb 23, 2007 at 4:02 AM
CHEVY22
  • 1,375 POSTS
no problem , we are all here to help in our spare time , good luck with the reapir , im sure when its all done you will think it was simple and have no problem doing it again, keep us updated
thanks
jim
Feb 23, 2007 at 4:07 AM
