Fuel Problem
LRAY
I have a 1989 gmc c1500 2WD Pickup,5.7Lt with 185K miles.The other day I had to tow my truck home because it would not crank back up. It appears to be a fuel problem. I can pour a little fuel into the Throttle body and it will crank,then die when the fuel runs out. I replaced the fuel pump in the tank. I checked the ecm fuse and injector fuse and they are ok. I have voltage at the fuel pump and voltage at the injectors. I turn the key to on position and put my ear to the gas cap and can hear something like the pump for about 2-3 seconds. What else can I check?
Apr 18, 2007 at 5:52 AM
STEELWEELS
  • 60 POSTS
possible fuel filter is bad
Apr 18, 2007 at 7:00 AM
LRAY
I took it off and could blow through it so I put it back on.
Apr 18, 2007 at 7:07 AM
