2003 GMC Sierra No 3rd Gear Shift
JENASHURST
i have a 2003 gmc sierra 1500 2wd 4.8 and im having trouble with shifting. Its an automatic 4speed. i can not get it to shift into 3rd gear. It goes into 1st and 2nd gear but wont go into 3rd gear. I will put it into driveand when it gets to 3rd gear it goes into nuetral. sometimes i can get it to catch 3rd then it goes into 4th fine. please help
i had it scaned and the two codes that came up are;
P0220 TP OR APP SENSOR 2 CIRCUIT PROBLEM
P0120 TP OR APP SENSOR 1 CIRCUIT PROBLEM
May 12, 2006 at 10:31 AM
LOSONE
  • 1,616 POSTS
You have a problem with the solonoid pack inside the transmission. Take it to a transmission expert as they are kind of tricky to replace. good luck
May 13, 2006 at 7:25 AM
Suggested Repair
Have a transmission specialist inspect and replace the internal solenoid pack, which is tricky to service.
Conversation Summary
The owner of a 2003 GMC Sierra 1500 with a 4.8L and 4-speed automatic cannot stay in 3rd gear; it drops into neutral, though it sometimes catches 3rd and then shifts into 4th. Scan codes were P0220 and P0120 for the throttle or accelerator pedal position sensor circuits. The expert attributed the shifting problem to the transmission solenoid pack and recommended having a transmission specialist replace it.
