2004 GMC Sierra 4x4 Shift Grinding
WESTY
  • 5 POSTS
2004 Sierra,auto,4x4 shift on floor hump.
Is it normal for the shift from 2 wd to 4 wd high to make a grinding noise sometime when its cold outside? GM says i can "shift on the fly"at some reasonable speed,but i have been shifting from a dead stop for fear of trashing the tranny. I thought i could shift with the truck moving,thus the "shift on the fly" terminology. Other than that the tranny drive is fine.
Thanks
Nov 3, 2007 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
yes you should be able to shift on the fly but i wouldnt attempt it. i usually do it on the stop it is a lot safer i have never shifted a shift on the fly with the truck moving. check for proper fluid level, the automatic hubs might not be locking also for the shift on the fly to work.
Nov 3, 2007 at 12:56 PM
WESTY
  • 5 POSTS
I posted my thanks earlier,but didn't see it on the site. I'm posting my thanks again.
westy
Nov 9, 2007 at 10:48 AM
BLACKOP555
  • 10,386 POSTS
no problem mate, proud to help ya.
Nov 9, 2007 at 11:50 AM
Suggested Repair
Check the 4x4 fluid level and confirm the automatic hubs are locking. Shift from 2WD to 4WD high while stopped rather than on the fly until the grinding is resolved.
Conversation Summary
The owner of a 2004 GMC Sierra asked whether grinding when shifting from 2WD to 4WD high in cold weather is normal and whether shift-on-the-fly is safe. The expert said on-the-fly shifting is possible but safer when stopped, and advised checking the fluid level and whether the automatic hubs lock.
