2007 GMC C1500 0171 and 0174 Codes
42,000 MILES • V8 • 4WD • AUTOMATIC
RUDY99
Ok, I've searched the boards and can't seem to find a solution. My 2007 GMC 5.3 truck will not start the first crank (about 5 seconds) and starts great on the second try. The truck seems to run fine once it is fire up. I am not having the idle problems or stalling as some of the other posters have had. Any help?
Jul 14, 2009 at 8:50 AM
  • 75,988 POSTS
P0171/P0174
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jul 14, 2009 at 9:32 AM
