Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
C1500
Engine
Oil Change
2006 GMC C1500 change oil display
2006 GMC C1500
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENMCCALL
MEMBER
1 POST
how do i reset the oil change message
Mar 7, 2010 at 12:34 PM
BMRFIXIT
Experienced Mechanic
To reset oil life monitor, turn ignition switch to RUN position, with engine off. Cycle accelerator pedal from closed throttle to Wide Open Throttle (WOT) 3 times within 5 seconds. CHANGE OIL SOON light will flash for 2 seconds when system is reset.
Mar 7, 2010 at 12:40 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
