I have (red) Transmission fluid leaking from somewhere really close to the front of my truck.I thought it was the cooling lines,but they are clean and dry.I checked the Transmission Cooler ,but all connections are tight and secure.The leak is right where all the different pulleys bolt on to the front of the motor.and its only leaking right at the bottom of the motor.Could it be coming from somewhere else other than the transmission cooling lines?
Oct 12, 2010 at 3:40 PM
