2005 GMC C1500
BASSPOW
Computer problem
2005 GMC C1500 V8 Four Wheel Drive Automatic
Will a dealer charge for using the code scanner to check engine light on? If so what is the best scanner
to but?
Feb 1, 2009 at 3:21 AM
JDL
  • 16,098 POSTS
Some of the national brand autostores will check some codes for free.
A code reader will only show codes, not live engine data.
A scanner will read codes and show live engine data. Some manufacturers do call a reader a code scanner.
Yes, I believe the dealership will charge for diagnostics/hooking up a scanner.
A high-end scanner that will show codes and live engine data can sell for several K.
If you just want a code reader, they cost less.
Feb 1, 2009 at 3:36 AM
BASSPOW
Thanks for the info
Feb 1, 2009 at 3:41 AM
