2004 GMC C1500 Speedometer Won't work
60,000 MILES • V8 • 4WD • AUTOMATIC
SASSINJEFF
The speedometer in my 2004 GMC Sierra 1500 4X4 won't work. I replaced the vehicle speed sensor (VSS) but it still won't work. What could I try next?
The speedometer is the only thing on the instrument cluster that isn't working. All other gauges and lights appear to be working fine and the truck is running very well.
Jul 29, 2008 at 12:48 PM
RHALL77
  • 3,361 POSTS
i would obtain a code scanner and see if vehicle speed sensor is reading in the engine control module. this would be something to start with. see what you can find out and get back to me
Jul 29, 2008 at 2:42 PM
RGBUNDENS
I believe there was a recall by GM for this problem (my 2004 Chevy Silverado was recalled). They had to replace the entire instrument panel.
[quote:127585fd1d="Sassinjeff"]Electrical problem
2004 GMC C1500 V8 Four Wheel Drive Automatic 60,000 miles
The speedometer is the only thing on the instrument cluster that isn't working. All other gauges and lights appear to be working fine and the truck is running very well.[/quote:127585fd1d]
Jul 29, 2008 at 2:55 PM
