Sometime when the ac is turned on it blows hot aire. The next time you turn it on it will blow ice cold.
Oct 31, 2008 at 2:08 PM
✓Experienced Mechanic
Hi:
I need you to check something. When it blows hot air, check and see if the compressor is locking up like it should. If not, check to see if there is power to the compressor.
