2002 GMC C1500 Ignition switch will not turn
TIERNEYTJ
2002 GMC C1500 104000 miles
Ignition switch will not turn. Truck is in park. Steering wheel is not locked. I can turn wheel freely. I can unseat the park/lock cable and move the shift lever. I cannot remove the cable because I can't move lock assembly to acc position. I can not remove cylinder because I can't turn switch. Any help will be greatly apprieciated.
Dec 9, 2007 at 5:52 AM
BLACKOP555
  • 10,386 POSTS
you can remove the cylinder without turning it, it just requires a drill, you can drill out the retaining pin with the ignition in the off position then pull it out! try some graphite lock lube first and try using a different key.
Dec 9, 2007 at 6:13 AM
