2002 GMC C1500 I can't get it started.
65,000 MILES • V8 • 2WD • AUTOMATIC
BJDOUGLAS
I ran my truck out of gas and after adding around 10 gallons of fuel it still won't start. I checked the fuses for the fuel pump and they are all in good shape. Any ideas?
Dec 10, 2007 at 5:50 AM
BLACKOP555
  • 10,386 POSTS
running a tank out of gas is the #1 way to kill a old fuel pump, or a new one at that! when you turn the key to on does the pump turn on? if so disconnect a line, does it pump out gas if either of the ones above doesnt work, replace the pump.
Dec 10, 2007 at 9:18 AM
