2001 GMC C1500 misfire problem
72,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEREMY77517
i have a 2001 gmc and it was sitting for bout a month and i pulled it out the barn and the 3rd time i went to start it it seemed like it took a few more crankes to start.within the next day and a half it went totally down hill.when the check engine light came on ot says random multiple misfire. i changed the distributor and rotor and spark plugs. no change. i thought i might have got bad gas athe station so i changed the feul filter and checked the feul for water and added some heet feul treatment. still nothing and before i dump anymore money into it was just wondering if you might know ofa common problem with chevy ignition system.any advise and knowledge would be greatly appreciated. thank you
jeremy
Jul 7, 2010 at 1:15 PM
  • 75,988 POSTS
Hi jeremy77517, Welcome to 2carpros and TY for the donation
Lets do below to determine if its fuel or spark problem and comeback with some results we start here
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 7, 2010 at 6:29 PM
