2000 GMC C1500 truck shakes when brakes applied at higher s
2000 GMC C1500
240,000 MILES • V8 • 4WD • AUTOMATIC
RICM
Abs does not work. Did not work when we purchased vehicle. Fuse was pulled, had vehicle checked by dealer and needs new abs pump.
We have replaced front pads and rotors. Replaced rear pads, caliper and rotors. Used top of the line Napa parts.
System was bleed.
We have not repaired the abs system yet.
Suggestions???
Ric
Jun 22, 2008 at 5:28 AM
MERLIN2021
  • 17,250 POSTS
Check front end parts for play, and your tires for a shifted belt. If you have a steering stailzer(shock looking) my money would be on that.
Jun 22, 2008 at 5:37 AM
