[quote:a36d982cc3="chadcapps1"]Heater problem
2000 GMC C1500 V8 Four Wheel Drive Automatic 111000 miles
Do you have to remove the dash to replace the heater core? Is this a job for a novice to tackle?
Any special tools?[/quote:a36d982cc3] ARE YOU SURE YOUR HEATER CORE NEEDS TO BE CHANGED? ALOT OF TIMES THE HOSE GETS PLUGGED RIGHT WHERE THE RUBBER HOSE MEETS THE PLASTIC ON THE HEATER CORE UNDER THE HOOD. MINE DID THE SAME THING AND I CLEANED IT OUT AND THE HEAT WORKED FINE.
Mar 21, 2010 at 9:20 AM
