2000 GMC C1500 BLEEDING BRAKE SYSTEM
GPIRPIRIS
Brakes problem
2000 GMC C1500 V8 Four Wheel Drive Automatic 48.000 miles
ONE BRAKE LINE EXPLODED FROM CORROSION , 3 OTHERS WERE LEAKING , THE REMAINDER 34" OF LINESWERE BADLY OXIDIZED AND DECIDED TO CHANGE ALL LINES,NOW MY MECHANIC IS UNABLE TO BLEED THE SYSTEM , THINKS THE ABS IS CAUSING THE PROBLEM BUT HE IS NOT SURE WHAT TO DO ,ANYONE HAS ANY TECHNICAL ADVISE OR WHAT THE SEQUENCE OF ACCOMPLISHING THE BLEEDING IS, I WILL APPRECIATE ANY TIPS!,GEORGE.
Mar 31, 2008 at 9:43 AM
BLACKOP555
  • 10,386 POSTS
have him bench bleed the master cylinder first, then install it and let the brakes gravity bleed, then bleed the rear right then rear left, then front right and front left wheels manually.
then use a scan tool to bleed the ABS module..
Mar 31, 2008 at 12:53 PM
