1999 GMC Sierra, 206000 Miles, Dead, No Power
TIM NORMAN
I turn the ignition and the truck will not turn over. Dome Light works intermitantly, but as soon as I turn the key all is dead. When I open the passanger door this morning a clicking noise came from under the dash.
Sep 7, 2007 at 7:05 AM
MERLIN2021
  • 17,250 POSTS
You must start with a fully charged battery! Do that and check back in...
Sep 8, 2007 at 2:10 AM
TIM NORMAN
[quote:657a425cda="merlin2021"]You must start with a fully charged battery! Do that and check back in...[/quote:657a425cda]
The battery is less than a year old. I found a loose connection at the ground strap to fire wall terminal. This seems to have taken care of the issue. Thank you for the response.
Sep 8, 2007 at 11:01 PM
