1999 GMC C1500 caliper bolt
1999 GMC C1500
150,000 MILES • V8 • 2WD • AUTOMATIC
CMIZZELL
rear caliper mount bolts will not come out after loosening. is ther a trick to getting them out?
Sep 18, 2010 at 7:45 AM
TOMBSTONE87
  • 9 POSTS
if the bolt loosens up but fails to remove then the bolt is probably stripped or frozen in the slide try loosening the bolt while using a flare nut wrench smaller than the diameter of the bolt head and pull out while loosening
Oct 19, 2010 at 3:41 AM
