1998 GMC C1500 won't stsr
163,000 MILES • V8 • 2WD • AUTOMATIC
TRAINERJ4
turns over, no fire from coil, replaced coil, dist cap, rotor, sensor on distributor. Gensys diagnostics shows no codes and data stream shows 170 plus rpms on turn over
Apr 3, 2010 at 4:58 AM
  • 110,248 POSTS
HAve you checked the crank sensor? Also, is there power to the coil?
Jun 5, 2010 at 1:25 PM
