1998 GMC C1500 Vacuum assist leak ?
136,000 MILES • V8 • 4WD • AUTOMATIC
E.T.
When I apply the brakes, most often, I can hear hissing under the dash where brake pedal rod goes through firewall. Sometimes it works fine, other times ,low speed in parking lot, pedal is hard, and brakes don't apply very well. (while engine revs are up-and-down a bit) . Is this a vacuum assist leak? Is that the round metal thing behind the master cylinder?
Oct 26, 2010 at 4:54 PM
WRENCHTECH
  • 20,760 POSTS
Yes, that is the brake booster and it will need to be replaced.
Oct 27, 2010 at 12:08 AM
