1998 GMC C1500 replacing heads
SHAWNARODRIGUEZ69
Engine Mechanical problem
1998 GMC C1500 V8 Two Wheel Drive Automatic
what is proper tourque sequence for replacing heads?
May 2, 2010 at 5:07 PM
HMAC300
  • 48,601 POSTS
start at the center and work your way out. it's supposed to be torqued to a certain point then use a torque angle to tighten. but if you go to 65 ' # in stages like 40-50-65 then you'll be ok.
May 21, 2010 at 10:41 AM
