1998 GMC C1500 Rear differential noise
128,000 MILES • V8 • 4WD • AUTOMATIC
RAY H
Just bought a 98 half ton ext. cab from friend, Know history of truck. Has been making abnormal diff. noise for 7 years. recently replaced outer and inner axle bearings and lube, same results. Pinion bearing seems ok. Gears in diff. looked good also. When accelerating or slowing down in drive have rotating noise similar to a slight grinding or rubbing noise loud enough to be very annoying and making me curios as to the life expectancy of the rear diff. Noise will quiet somewhat when coasting and gas pedal is pressed slightly. Any help you can offer would be greatly appreciated! Thanks, Ray
May 4, 2010 at 2:19 PM
HMAC300
  • 48,601 POSTS
this could be a tire problem, depending on the tread pattern on the tires. you could have rust in the brake drums making the sound as well. Especially since you have taken the rear cover off and everything looks ok. Usually if a rear end makes a noise it's a whining noise not grinding or scraping. Also check the u'joints
May 21, 2010 at 10:38 AM
