1998 GMC C1500 Not receiving fuel
HD1500
Electrical problem
1998 GMC C1500 V8 Four Wheel Drive Automatic 180k miles
I dis a motor swap on the truck, the ngine starts and runs for about 5 seconds everytime it turns over, fuel pump has 65 psi new fuel filter new distributor sensor cam sensor reads fine, it seems like it's starting off fine but then dies because the fuel injectors aren't injecting, so I'm unsure what to do next my ECM is fine everything seems to work, I haven't checked the tps or determined if it needed a crank sensor relearn, can you help?
Mar 4, 2010 at 9:51 AM
  • 110,246 POSTS
Is the security light staying on?
Jun 5, 2010 at 2:24 PM
