1998 GMC C1500 No Brake Lights
130,000 MILES • V8 • 4WD • AUTOMATIC
DRACOINAZ
I have no brake lights or voltage to the rear of the harness. So far I have replaced the simple items such as the interior fuse, the fuse under the hood in the power distribution compartment, the brake relay and finally the the brake switch attached to the brake pedal, but still nothing.
Oct 24, 2008 at 12:33 PM
JNOVACK
  • 723 POSTS
do you have parking lights
Oct 24, 2008 at 2:09 PM
DRACOINAZ
Yes. I have parking lights, turn signals, reverse lights.
Oct 24, 2008 at 2:13 PM
BMRFIXIT
  • 19,053 POSTS
Hello
tools needed for the test a simple test light and or volt meter locate the brake light switch on top the brake paddle check for power at one of the two wires do you have battery power ?if not problem is no supply volts (org wire)check fuse #1 inside the truck fuse panel if 4way flasher work but no power to the brake switch check the wire most common when installing an alarm system or remote starter they cut them wires .check them check fuses and wiring on the circuit if yes and u have power step on brakes u should have power on the other wires if not recheck the switch and its adjustment check if 3rd brake light on and if so suspect the multifunction switch.
Oct 24, 2008 at 2:22 PM
JNOVACK
  • 723 POSTS
ok now this may sound stupid but check the bulbs make sure they are 1157 bulbs and put in the wright way I have found this to be the case on alot of chevys
Oct 24, 2008 at 2:56 PM
