1998 GMC C1500 horn
154,000 MILES • V8 • 4WD • AUTOMATIC
WINGSTEALER
i recently replaced the blinker assy and in doing so i bent the copper ring inside the steering assy behind the wheel that the blinker contact pin touches after i did the install the horn would honk at a certain point when i turn the wheel. i have readjusted the copper ring and it now it sitting flush like before i did the replacement but the horn still honks when i turn how would i go about fixing it thank you
Feb 2, 2010 at 8:03 AM
FACTORYJACK
  • 4,159 POSTS
It is hard to say what is wrong without seeing it. It is grounding out somewhere when rotating. If you take the inflator(airbag) off, or away from the wheel, does it still happen? The only thing I can suggest is replacing the contact ring. That may or may not correct it, I don't know if it is assembled correctly.
Feb 2, 2010 at 3:30 PM
WINGSTEALER
well im not really a chevy/gmc person (subaru) but i will take it apart and see what i can find out
i will also add some pictures
Feb 3, 2010 at 1:50 PM
FACTORYJACK
  • 4,159 POSTS
Sounds good, let me know the progress. Try it with the airbag off and see if it still acts up though.
Feb 3, 2010 at 2:00 PM
WINGSTEALER
here are some pics
https://images.2carpros.com/forum/automotive_pictures/474780_IMG_0761_1.jpg
https://images.2carpros.com/forum/automotive_pictures/474780_IMG_0765_1.jpg
Feb 9, 2010 at 10:23 AM
FACTORYJACK
  • 4,159 POSTS
Everything looks fine there, is there something you are trying to illustrate. Does the horn blow with the system in that state you have there?
Feb 9, 2010 at 3:40 PM
WINGSTEALER
yes still blows when you turn the wheel
Feb 9, 2010 at 7:31 PM
FACTORYJACK
  • 4,159 POSTS
It is shorting to ground further in. If you take the plastic slug out(with the two red wires)of contact, and it still does it, then it is not the steering wheel. It could possibly be the lock plate. If you remove the wheel, and SIR coil, loosely reinstall the wheel and see if it still does it. Then remove the lockplate, and the contact ring and see if it still does it.
Feb 10, 2010 at 3:38 PM
