1998 GMC C1500 heater problems
150,000 MILES • 6 CYL • 2WD • MANUAL
JOSH.MURFIN
my name is Josh and i am having a heater problem.
when i turn on my heater it only blows out of my defrost vent it will not turn hot not even luke warm.
my heater core it hot and so are both of my tubes going into the truck through the fire wall. my radiator and the aux is full, but my switchs are also not switching from floor to front it only stays on defrost vent and only blows cold i have no idea what to look at to fix this.
Thank You,
Josh
Jan 29, 2009 at 10:37 AM
DON OLIVER
  • 101 POSTS
the heater is supposed to defer to the windshield if the control head fails. sounds like your problem. the unit is replaced as an assembly. it controls heat and direction of air
Jan 29, 2009 at 10:47 AM
