1998 GMC C1500 distributor cap
152,000 MILES • V8 • 4WD • AUTOMATIC
J WILLIS
Have replaced distrubitor cap three times in six months, is this possably a problem with distrubitor?
Jul 7, 2008 at 8:37 AM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:8b25fdc74d="j willis"]Electrical problem
1998 GMC C1500 V8 Four Wheel Drive Automatic 152000 miles
Have replaced distrubitor cap three times in six months, is this possably a problem with distrubitor?[/quote:8b25fdc74d]
Ok, well what is the problem you are having? Without knowing your problem we cannot honestly say.
Jul 9, 2008 at 9:57 AM
REYES45
It`s very possible that your dist. went bad. I had the same problem with my 98 sierrs, the caps would last about six months then three then it needed one about every six weeks. I changed the ignition coil thinking a wesk spark might be fauling out the cap but it didn`t make a difference. Changed the distributor and that fixed the problem. Good luck!
Dec 28, 2008 at 1:51 AM
