1998 GMC C1500 cruise control problem
100,000 MILES • V8 • 4WD • AUTOMATIC
CAPT_MORGAN
my cruise control started to work seldomly and now never.fuse is ok.how can i troubleshoot this and find the problem part to replace????
Mar 29, 2008 at 10:54 PM
MASTERTECHTIM
  • 4,750 POSTS
i can tell you from experience that when this happens its almost always the switch on the steering column causing the problem. there are tiny wires going to it and over time they break. to test at the base of steering column use a test light to ground and see if it will light when you hit each button.
Mar 30, 2008 at 12:30 AM
