1998 GMC C1500 brakes not releasing
1998 GMC C1500
215,450 MILES • V8 • 2WD • AUTOMATIC
1970SIS
brakes were dragging on left side when applying brakes so I installed new calipers and new pads, bled brakes totally, all new fluid with no air bubbles, brakes are now grabbing hard left and won't release from rotor causing brake to really heat up. what can i do to fix this problem?
Mar 15, 2010 at 5:57 AM
HMAC300
  • 48,601 POSTS
if you have done that and it still locks up check your hoses as they get bad and cause a problem like you describe.
Apr 2, 2010 at 1:11 PM
