1997 GMC C1500 Won't stay warn
ALOZANO
Heater problem
1997 GMC C1500 6 cyl Two Wheel Drive Automatic
I recently replace the water pump the thermostat on my truck the pump was leaking and the heater works but was not giving out heat. after replacing the parts I had the engine flushed and new coolant installed. I tested the heater and it would warn up but then start to cool down it will not stay warn.
Mar 3, 2010 at 2:42 PM
  • 110,248 POSTS
Are both heater core hoses staying hot?
Jun 5, 2010 at 2:28 PM
