1997 GMC C1500 tart trouble
JOSE MANUEL
Engine Performance problem
1997 GMC C1500 V8 Four Wheel Drive Automatic
for the last week or so my truck has had trouble sarting makes a big noise, seems coming from the flywheel or somewhere from down there, I changed the fuel filter, thinking that the was the problem,but
it wasnt, I don't know if it is the fuel pump, a sensor or what, Can somebody help me pin point what can
actually be , I really appreciated, thanks Manny
Sep 27, 2008 at 8:41 AM
  • 75,988 POSTS
The starter is it cranking the engine over or it cranks over and refuses to start
Sep 27, 2008 at 9:02 AM
JOSE MANUEL
It cranks the engine but wont start, seems like fuel is
not reaching the intake I wouldn't know to be sincere, I can hear the fuel pump working but I don't
knw if is working properly or not. Is there a way to
find out if is really the pump for sure?
Sep 27, 2008 at 9:13 AM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge designed for your fuel system-if okay-check if the injector/s are pulsing meaning its opening and closing-by listening for clicking noise or you can use a noid light to check
Sep 27, 2008 at 9:22 AM
JOSE MANUEL
I had a problem staring my truck at first I tought that
could be the fuel pump but appearently is not, Now
coudl a faulty starer alter the truck's timming because
it shakes buyt not starts. any help will be greatly appreciated, thanks Manny
Oct 18, 2008 at 6:57 AM
  • 75,988 POSTS
Now
The starter's job is to crank the engine over that's all its got nothing to do with the car shaking
Oct 18, 2008 at 10:17 AM
JOSE MANUEL
Back to you again, thanks for the time and the imput
I took and test the starter and there is nothing wrong with it, Now can the engine's timming can be
moved by mistakeinly move the distributor or can the distributor can be the caused of the problem?
Oct 20, 2008 at 10:12 AM
  • 75,988 POSTS
moved by mistakeinly move the distributor: You cannot move the distributor mistakenly-you have to loosen the holddown bolt/s for it to be out of time.
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Oct 20, 2008 at 11:40 AM
