1997 GMC C1500 po172 and po 175
162,000 MILES • V8 • 2WD • AUTOMATIC
COBRA1
I keep setting both bank 1 and bank 2 rich at the same time
I can erase the mil and drive non stop and the codes will never show up except in pending codes but as soon as i turn the engine off the codes will show up
i have replaced the o2 sensors, the maf is with in limits, fpr is replaced, fuel pressure is good,
when these codes are set my gas milage goes down to about 10mpg when the codes are set i get about 19 on the highway.
Oct 23, 2008 at 4:36 AM
  • 75,988 POSTS
Hi cobra1 and welcome to 2carpros
P0172/P0157-rich codes
Could be a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Oct 23, 2008 at 4:43 AM
COBRA1
i have changed or checked all those items and they are all good
could the pcm cause the problem of both codes being set at the same time
Oct 23, 2008 at 4:49 AM
  • 75,988 POSTS
i have changed or checked all those items and they are all good-Your last stop is the computer-however double checked the items again something is making it go rich-how about the O2 sensor is it switching -
Oct 23, 2008 at 4:55 AM
