1997 GMC C1500 noheat and wipers only work on high
444LLL
Heater problem
1997 GMC C1500 6 cyl Two Wheel Drive Manual
i have a 97 GMC 1500 and nothing happens when i turn on the heat or defrost i turned it on one day and smoke came out and now nothing at all and my wipers will only work in the on position
May 6, 2010 at 3:11 AM
HMAC300
  • 48,601 POSTS
have a pro check this as it can be a switch/relay/motor or resistor for the heat. the wiper may be a circuit board that has gone bad and not allowing anything to work.
May 21, 2010 at 10:30 AM
