1997 GMC C1500 No tach,speedo, gear indication, Service eng
1997 GMC C1500
17,500 MILES • V8 • 4WD • AUTOMATIC
GWK
The tach, speedometer are inop, service eng. soon light is illuminated, gear indication light is inop - have checked all fuses in L/H driver side interior fuse block and fuse and relay center L/H rear of eng. compartment and the four fuses blow dash above the pedals - are there anymore? have checked connectors at tranfer case and easily accessable connectors on transmission (the ones on sides and shift mech)......eng. dose not seem to shift at all on accelloration....no problems move gear shift on steering colum....will a diagnostic computor help here.....have no previose history or problems related to this..... thx gwk
Feb 10, 2009 at 7:14 AM
MMPRINCE4000
  • 8,548 POSTS
Take it to any autoparts store and get a free Powertrain scan ("P") codes.
You may also want to take it to a shop and get the ("C") chassis, ("B") body and ("U") communictions codes scanned.
Autoparts stores can, generally , only scan "P" codes, but it is free, so start there.
The IP problem may well be a problem with the IP itself, assuming all fuses are good.
Feb 10, 2009 at 10:05 PM
GWK
Thx for the input...for clarrification for me...what is"IP".....unsure what your refering to here...not up on your accronimes...is this Input Powertran??
Thank you...gwk...
[quote:0c6c5bae3c="mmprince4000"]Take it to any autoparts store and get a free Powertrain scan ("P") codes.
The IP problem may well be a problem with the IP itself, assuming all fuses are good.[/quote:0c6c5bae3c]
Feb 11, 2009 at 6:59 AM
GWK
Thank you...gwk...
[quote:0c704d673a="mmprince4000"]Take it to any autoparts store and get a free Powertrain scan ("P") codes.
The IP problem may well be a problem with the IP itself, assuming all fuses are good.[/quote:0c704d673a]
MMPRINCE4000
  • 8,548 POSTS
Instrument Panel.........Sorry for the confusion.
Feb 11, 2009 at 11:59 PM
GWK
C - B - U scans are dealer only scan options correct?.....will one of these confirm an intrament panel failure.. or at least help narrow down to a higher degree of certianty when they are compared or reveiwed with p code readouts....again I thank you for your time and efforts....if possible - plz e mail this responce to gwkjetmech@rocketmail.com....coming up on my days off....thx....
[quote:f5f5fb967d="mmprince4000"]Instrument Panel.........Sorry for the confusion.[/quote:f5f5fb967d]
Feb 12, 2009 at 7:02 AM
MMPRINCE4000
  • 8,548 POSTS
Scans other than "P" scans are generally dealer or ASE certified garage.
Many garages have the scan tools necessary to scan all codes.
Check with GM about your IP (instrument panel :) ) problem, they may have been recalled and it would not cost you anything.
Feb 12, 2009 at 2:25 PM
