1997 GMC C1500 how to disconnect pushrod from brake pedal
LWHENSON
Brakes problem
1997 GMC C1500 V8 Four Wheel Drive Automatic 200k miles
How do you disconnect pushrod from brake pedal. Don't have much room and eyesight bad. Could use some help on what I am looking for and working with. Thank you
Sep 24, 2009 at 11:27 AM
  • 75,988 POSTS
Remove booster to firewall nuts from inside the vehicle and disconnect the push rod from the brake pedal arm
Sep 24, 2009 at 11:47 AM
