1997 GMC C1500 fuel pump
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
KOLTON
being somewhat of a backyard mechanic i need some info on changing my fuel pump, i know its located in the tank so im assuming the first step is to drop the gas tank then..................
Jan 28, 2008 at 11:46 PM
SERVICE WRITER
  • 9,123 POSTS
The sending unit and the pump are held in by a lock ring. IT is removed counter clock wise. When you replace the pump, I would use a delco or delphi pump and replace the connector going to the plug of the sending unit. Replace the fuel filter at the same time to maintain the warranty on the pump.
Jan 28, 2008 at 11:54 PM
