1997 GMC C1500 compressor will not come on.
WTELWE
Air Conditioning problem
1997 GMC C1500 6 cyl Two Wheel Drive Automatic
The clutch on the compressor will not engage. I have checked the fuses @ the a/c relay. I have taken the dash control switch unit out. The a/c on button seems to engage ok but in the past I have had to push several times to start the a/c. What can I try next?
Jan 17, 2010 at 3:40 AM
DR LOOT
  • 2,311 POSTS
you must be a homesick Eskimo wanting your AC to work in the winter? I believe the only other problem is that you are low on 134A, check your AC pressure, or it could be a bad pressure switch located on the low side hoes.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 22, 2010 at 4:15 PM
