1996 GMC C1500 Replaced Distributor
208,000 MILES • V8 • 4WD • AUTOMATIC
MYKEJONES
I replaced the Distributor about 2500 mile ago, the vehicle ran great until the other day when it totally lost power and showed a code of Multiple misfire. I have checked the plug wires and cap and rotor and now the vehicle wont start. any suggestions?
Oct 30, 2009 at 6:51 AM
  • 75,988 POSTS
If its cranking over and refuses to start do below might lead you somewhere
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 30, 2009 at 7:04 AM
