1996 GMC C1500 Fuel injection system issue
265,000 MILES • V8 • 4WD • AUTOMATIC
WHYBULL57
Has new fuel pump, filter, dist. cap and rotor. Fuel pumps through new filter.
Fuel pump relay does energize.
Is there a simple method to check the fuel injection system and injectors to verify they are functioning correctly?
May 3, 2009 at 7:48 AM
  • 75,988 POSTS
Do you hear the fuel pump for a few secs-If so check fuel pressure and injection pulses-If not check the fuel pump relay and fuse.
May 3, 2009 at 9:11 AM
