1995 GMC C1500 Whining when steering wheel is turned either
1995 GMC C1500
140,000 MILES • V8 • 4WD • AUTOMATIC
RUACH34
Recently I got the two front tires stuck in my yard in a trench. The back wheels could not get traction and spun when transmission engaged. To try and get it out I placed it into four wheel drive and tried to engaged the front tires to get out, no such luck.
Eventually I got it out but now the steering column whirrs or whines when I turn it from neutral in either direction.
What are the steps to diagnose this problem?
Mar 22, 2009 at 2:22 AM
MERLIN2021
  • 17,250 POSTS
Check fluid level in pump reservoir, check for leaks in hoses and steerong box, especially at the bottom seal(sector shaft).
Mar 22, 2009 at 5:28 AM
