1995 GMC C1500 water pump
1995 GMC C1500
BRIDGETDAVIS101
Engine Cooling problem
1995 GMC C1500 6 cyl Four Wheel Drive Automatic
my water pump is leaking, im getting it fixed but my husband has to drive it to work for a couple of days. what should we do until we get this fixed
Oct 22, 2008 at 3:39 AM
DLOBI
  • 125 POSTS
Monitor the coolant level in the overflow resevoir and the radiator. If ther coolant gets low it will run hot and/or overheat. Carry a 50/50 mix of antifreeze and water in the truck at all times. Maybe 2 gallons would be safer than one. Never open up the radiator cap when the engine is hot as the expanded coolant will be under pressure and can burn you.
Oct 28, 2008 at 5:02 AM
