Can you tell me how to take of the pulley from the AC compressor w/o taking of the compressor?
Thank you,
Phil
Jun 20, 2010 at 4:21 AM
HMAC300
✓Experienced Mechanic
you have to take the nut off the shaft then install the SPECIAL TOOL to remove the clutch and then there should be a snap ring holding the pulley/bearing on.
