1995 GMC C1500 No Power
15,000 MILES • V8 • 2WD • AUTOMATIC
NWASHINGTON
The starter is not receiving enough power. We have check the battery and the alternator they are both fine. It just clicks and the starter is good.
May 3, 2010 at 2:17 PM
  • 110,251 POSTS
How did you check the starter? Also, did you check the starter relay? Finally, have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should be getting 12+ volts. Let me know what you find.
Jun 5, 2010 at 11:55 AM
