1995 GMC C1500 Heater motor stops working intermittently
1995 GMC C1500
150,000 MILES • V8 • 2WD • AUTOMATIC
RLINK
What could be the caause of my heater motor stops working and then starts again? One day I went to start my truck and the heater motor wasn't running, so I turned the on/off switch on all the settings but nothing happened, then the next day I went out to the truck and turned on the ignition switch and the heater motor went on, now I went out there again today and the heater motor won't go on again. Is this the on/off/hi/lo switch going bad or is there something else that I should be looking at?
Jan 31, 2010 at 10:24 AM
DOCFIXIT
  • 18,828 POSTS
Using test light see if power is to motor when blower is not working
Feb 1, 2010 at 7:10 AM
