1995 GMC C1500 Fuel injector
1995 GMC C1500
120,000 MILES • V8 • 2WD • AUTOMATIC
SBARKER249
I'm getting no electric pulse to the injectors. TBI
Jun 4, 2010 at 10:05 AM
Check and test the ECM I Mini fuse 20amp in the underhood fuse and relay center if okay you should have power on the pink wire at the injector harness if so your ground driver circuit on the computer is defective-
Jun 4, 2010 at 10:29 AM
