1995 GMC C1500 Fuel injector
SBARKER249
  • 1995 GMC C1500
  • V8
  • 120,000 MILES
I'm getting no electric pulse to the injectors. TBI
Friday, June 4th, 2010 AT 5:05 PM
Check and test the ECM I Mini fuse 20amp in the underhood fuse and relay center if okay you should have power on the pink wire at the injector harness if so your ground driver circuit on the computer is defective-
Friday, June 4th, 2010 AT 5:29 PM
