Check the refrigerant pressure, if it is low you need to locate the leak, repair it and have the system evacuated and recharged, If the system is full, see if the compressor is running and cycling properly. You can jump the cycling swith on the to of the dryer and see if the compressor starts and the system blows cold.
Sep 10, 2008 at 11:33 AM
