1995 GMC C1500 1995 GMC 1500 Fuel Injector issues
189,000 MILES • V8 • 2WD • MANUAL
GABRIELGILLETTE
My 1995 GMC 1500 V8 305 is not starting... fuel is not comming out of the injectors.. when I put a little gas into the throttle body it starts and quickly sputters and dies. I didn't hear the fuel pump running so I dropped the tank and replaced the fuel pump....same symptoms except fuel pump runs, pumps up to pressure and stops... so I checked the fuel filter. It was full and needed replaced... so i did.. same symptoms.... so I detached the the fuel line at the throttle body and turned it over to see if fuel was getting to the injectors.... fuel came out fine. so I am fairly certain the injectors are the issue. what do I do next?? please help.
Mar 5, 2009 at 12:40 PM
JERRYGOODWRENCH
  • 77 POSTS
You need to check each inj for short or too many ohms resistance. Unplug each inj and check the resistance on each one. Should read around 11 ohms or so .If you find one that is way out of range then there is your problem..
Apr 18, 2009 at 11:29 PM
