1995 C1500 Suburban Alternator Problems
RENOJADERA
I have a 1995 GMC Suburban C1500 2wd. I replaced the alternator about a year about with a reman unit. Recently, I have been getting an evil grinding noise from the alternator. When looking under the hood I notice the black fan (right behind the pulley) is rubbing up against the outside of the alternator. Sometimes it'll happen and sometimes it'll just go away. I tried bending back each fin just slighting so it does not grind against the main part of the alternator.
Why is this happening? and How can I avoid it from happening again?
Thanks for your help!
Apr 25, 2006 at 3:40 AM
LOSONE
  • 1,616 POSTS
You may have installed the cooler fan backwards. I don't advise bending it. Also it sounds like you might need a new belt.
Apr 25, 2006 at 3:54 AM
RENOJADERA
but the alternator was all ready assembled when received. All i did was R & R with the new unit. I believe it was only 3 bolts total. One other thing, when looking at photos of other alternators, the fan is on the right direction. The belt is also nice and tight, but I will take another look if it really needs replacing.
Thanks
Apr 25, 2006 at 4:01 AM
