no heat
150,000 MILES • V8 • 4WD • AUTOMATIC
KRETEMAN
my heat diplay flashes when i turn it on. all the controls on the heater work except the heat control just flashes. i have ruled out all the usuall suspects so i guess im wondering if the flashing is an indication of a problem im not aware of. thx
Sep 8, 2010 at 12:02 PM
WRENCHTECH
  • 20,760 POSTS
Yes, the flashing is a telltale for a malfunction in the system usually a temperature blend door actuator. Here is a guide that will help you see how to change it out.
Sep 8, 2010 at 12:20 PM
KRETEMAN
Thanks for the post, it was the blend door actuator I go a new one for $56.00. I love this site.
Sep 8, 2010 at 3:31 PM
2CP-ARCHIVES
  • 4,540 POSTS
the fan on my heater wont work what things do I need to check for?
Nov 29, 2018 at 10:02 AM (Merged)
HMAC300
  • 48,601 POSTS
check your blower relay on firewall and resistor in the heater box near blower. see if those are getting power if they are then they may be bad if not it can be aswitch or blown fuse.
JACK354
heater quit working,dash control does not light up,do you know what is wrong with it ?
start with checking the fuses with a test light. it has to have power to operate the controls
This guide can help as well
https://www.2carpros.com/articles/car-heater-not-working
MIKEY11
Hello
I have the following truck above. I have no heat blowing and I did the following already.
Replaced the thermostat
Replaced the coolant temp plug
There is no buildup on the window from the heater coil or any water on the bottom anywhere.
The hoses are hot
Someon told me maybe my whole heater control unit needs replacing becuase when you select the control to either go to vent or bottom it only blows on the defrost part. The 2 butttons for a/c or recircluation do not light up when you press them. However the low,med,high knob works fine but again only blow cold air onto the winshied. Before I goto to the junkyard and waste money does anyone have any ideas.
Thanks for reading this
Mike
A-TRAIN
  • 6 POSTS
I had an 88 chevy with the same problem. Replaced the heater core, and solved the problem.
KRETEMAN
when i turn the heater on the display flashes for about 2 or 3 minutes. it also will not let me adjust the temperature control. it just blows cold air. ive ruled out all the usual suspects. help please, i dont want to spend a fortune at the dealer.
Nov 29, 2018 at 10:03 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
Your probably going to need the dealer to get the diagnosis confirmed but they had a ton of trouble with the control heads on those. That's the part that's flashing.
